SupahFox's avatar
Apr 28, 2021
Orbi disconnects after ip change
So, my ISP by default changes the IP address every 6 hours and orbi disconnects for 1 minute aprox. I contacted my ISP and it said that it was the orbi router. Pls help
Firmware: RBR20 V2.6.2.104
(the modem is configured in bridge mode and orbi in router mode)
    • SupahFox's avatar
      SupahFox
      Tutor
      Antel, the only ISP here in Uruguay. In 2022 we'll have Starlink lol
      • LlamaLarry's avatar
        LlamaLarry
        Luminary
        That's a crazy short lease time, but you have to work with what you get.
        You can go to Advanced -> Internet Port -> Connection Status in the Orbi UI and Release then Renew when your ISP refreshes your IP.  This will be faster than waiting for the Orbi to do it by itself.
    • SupahFox's avatar
      SupahFox
      Tutor
      I think only business can request a static IP for this ISP if I remember correctly
      • CrimpOn's avatar
        CrimpOn
        Any one who will PAY for a static IP can have one.  It's the money the ISP cares about.
  • CrimpOn's avatar
    CrimpOn
    On the Orbi web interface, Advanced Tab, the blue box labelled "Connection Status" will display the lease that was obtained and the time remaining. Typical DHCP practice is for the client to begin attempting to renew the lease when it is half expired.  If the lease provided was for six hours, there should always be more than three hours remaining because the Orbi will renew for another six hours at the three hour mark.  It would be useful to know when the ISP issues a different IP address.(Is it during a regular renewal?  Just "out of the blue" in the middle of a lease period?)  It is actually a different IP address every time?
    This may be a situation where the modem should not be in bridge mode. (Lessor of two evils: give up some applications like port forwarding, VPN, etc. vs. suffer 1 minute outages every six hours)
    I had never considered what changing client IP addresses would do to every TCP connection that has been established.  Every data packet that arrives at the ISP for this IP address now has to go ..... where?
