McRob1
Aug 23, 2018Luminary
ReadyNas Pro 6 High Temperature
I am running firmware version 6.9.3 on a old ReadyNAS Pro 6. Lately I have noticed that the system temperature is running higher than normal. I have noticed temperatures up to 68C. Hard drives and...
powellandy1
Aug 24, 2018Virtuoso
Hi
My Pro6 on OS6 always used to run about 62oC. I'm sure I read somewhere that the sensor is pretty close to something hot, so the readings are somewhat misleading. I had put a Noctua fan in mine as well, after one summer getting temperature warnings at 80oC!!
Cheers
Andy
Aug 24, 2018Guru - Experienced User
BTW, I also replaced the chassis fan with a Noctua, but didn't see any change in temperature. It is quieter though.
