Jens3's avatar
Jens3
ReadyNas pro 6 memory test error 999
Hi!  Anybody here that knows what Memory Test result error code 999 means?    It is from a ReadyNas Pro 6 that won't boot right. (Boot Meny works fine though.) I let Memory Test run over nigh...
  • Marc_V's avatar
    Marc_V
    Jul 05, 2018
    Hi Jens3
    It would be best to download the full logs so we can check.
    Have you tried using RAIDar to download the full logs?
    On Tech Support mode if correct, you can look at /var/log/ and see if you can get to diagnostic.log, kernel.log, meminfo and system
    Regards
ProSupport for Business
