J_Malmlund
Nov 30, 2021Tutor
ReadyNAS Pro 6 on readyos v6.10.6 no frontview on boot
First of all let me right of the bat start by acknowledge that I'm aware I'm running "unsupported" software on legacy hardware. My setup has been working good for years and years since I due to secu...
- Dec 02, 2021
Not a lot of clues here. You might want to search through all the log files and see if there is more information on what is killing apache. It might be one of the add-ons/apps (including ones you uninstalled that might not have uninstalled correctly).
The brute-force "fix" is to back up the files, do a factory default, rebuild the NAS, and then restore the data.
J_Malmlund
Dec 02, 2021Tutor
Yes, I’ve tried the boot menu OS reinstall but that didn’t help which is so wired!
Dec 02, 2021Guru - Experienced User
