vaprasad
Oct 11, 2022Aspirant
ReadyNAS Pro 6 running OS 6.10.8 Volume Missing?
Pro 6 running ReadyNAS OS 6.10.8 with RAID 6. Unable to access any of my shares. Web indicates "No volumes exist. NETGEAR recommends that you create a volume before configuring other settings. Na...
Marc_V
Oct 11, 2022NETGEAR Employee Retired
Can you download the full logs and send it to us via PM? You can also email [email protected]
We may need to check if the array can still be mounted or if it will need data recovery.
Note: Data recovery charges may apply.
HTH
- vaprasadOct 12, 2022Aspirant
Thanks Marc,
I just sent the log file via email. The PM option wouldn't allow me to attach the log file.
Thanks,
Vijay
- StephenBOct 12, 2022Guru - Experienced User
vaprasad wrote:I just sent the log file via email. The PM option wouldn't allow me to attach the log file.
FWIW, the usual method is to put the zip into cloud storage (dropbox, etc), and PM a link.
Thanks for the heads up. Just PM'd the link to Marc.
- vaprasadOct 16, 2022AspirantTech support said the device is old and no longer supported.
What steps can I take to troubleshoot?
So far, I've run a disk test which indicated:
Disk test failed in channel 3.
I powered off the unit and replaced disk 3.
Web interface still shows my volume as dead or inactive and still shows disks 1,2,4,5,6 in red and still tells me that I need to remove inactive volumes.
The device was configured with RAID 6, so I'm confused that it is not trying to rebuild the volume at all.- StephenBOct 17, 2022Guru - Experienced User
vaprasad wrote:
Tech support said the device is old and no longer supported.Not only that, they never supported OS-6 on legacy NAS like the Pro-6.
It sounds like you have no backup of your data - is that correct?
vaprasad wrote:
The device was configured with RAID 6, so I'm confused that it is not trying to rebuild the volume at all.Did the mods find anything in the log zip?
Sometimes the volume gets out-of-sync.
- vaprasadDec 09, 2022Aspirant
No backups. I got lazy about getting a replacement backup drive as utilization increased.
Never heard back from the mods on the what could be found.
