vaprasad
Oct 11, 2022Aspirant
ReadyNAS Pro 6 running OS 6.10.8 Volume Missing?
Pro 6 running ReadyNAS OS 6.10.8 with RAID 6. Unable to access any of my shares. Web indicates "No volumes exist. NETGEAR recommends that you create a volume before configuring other settings. Na...
Marc_V
Oct 11, 2022NETGEAR Employee Retired
Can you download the full logs and send it to us via PM? You can also email [email protected]
We may need to check if the array can still be mounted or if it will need data recovery.
Note: Data recovery charges may apply.
HTH
vaprasad
Oct 12, 2022Aspirant
Thanks Marc,
I just sent the log file via email. The PM option wouldn't allow me to attach the log file.
Thanks,
Vijay
- StephenBOct 12, 2022Guru - Experienced User
vaprasad wrote:I just sent the log file via email. The PM option wouldn't allow me to attach the log file.
FWIW, the usual method is to put the zip into cloud storage (dropbox, etc), and PM a link.
- vaprasadOct 12, 2022Aspirant
Thanks for the heads up. Just PM'd the link to Marc.
