vaprasad
Oct 11, 2022Aspirant
ReadyNAS Pro 6 running OS 6.10.8 Volume Missing?
Pro 6 running ReadyNAS OS 6.10.8 with RAID 6. Unable to access any of my shares. Web indicates "No volumes exist. NETGEAR recommends that you create a volume before configuring other settings. Na...
vaprasad
Oct 16, 2022Aspirant
Tech support said the device is old and no longer supported.
What steps can I take to troubleshoot?
So far, I've run a disk test which indicated:
Disk test failed in channel 3.
I powered off the unit and replaced disk 3.
Web interface still shows my volume as dead or inactive and still shows disks 1,2,4,5,6 in red and still tells me that I need to remove inactive volumes.
The device was configured with RAID 6, so I'm confused that it is not trying to rebuild the volume at all.
Oct 17, 2022Guru - Experienced User
Not only that, they never supported OS-6 on legacy NAS like the Pro-6.
It sounds like you have no backup of your data - is that correct?
Did the mods find anything in the log zip?
Sometimes the volume gets out-of-sync.
- vaprasadDec 09, 2022Aspirant
No backups. I got lazy about getting a replacement backup drive as utilization increased.
Never heard back from the mods on the what could be found.
- StephenBDec 10, 2022Guru - Experienced User
Marc_V and JeraldM - did you get the PM? If so, did you see anything in the logs?
- Marc_VDec 12, 2022NETGEAR Employee Retired
Apologies for the delayed response it seems that my PM did not reach you properly.
This issue happened after the upgrade to 6.10.8 and I only found BTRFS errors that affected the mounting of your volume. If you have backup, you can opt to restore the volume by re-initializing the NAS and restore data from backup. However, this is not the case so I think a Data recovery service would be needed. I will send another PM as well.
Thanks StephenB for the mention
HTH
