chainlinc
Aug 28, 2018Guide
ReadyNAS Pro 6 volume loss after resync
I
1) I went on vacation from 2018-08-13 until 2018-08-25, upon my return, the (OS: 6.9.3, BIOS: Flame6-MB 2010-07-26) ReadyNAS Pro 6 NAS (protected by a 1500VA UPS) was inaccessible. Upon reboo...
mdgm-ntgr
Aug 28, 2018NETGEAR Employee Retired
Can you download your logs and send them in please (see the Sending Logs link in my sig)?
chainlinc
Aug 29, 2018Guide
The logs have been sent.
- mdgm-ntgrAug 29, 2018NETGEAR Employee Retired
This is a data recovery situation. From kernel.log we see.
Aug 28 15:06:47 rnpro kernel: Btrfs loaded, crc32c=crc32c-generic Aug 28 15:06:47 rnpro kernel: BTRFS: device label 540ed803:root devid 1 transid 1169013 /dev/md0 Aug 28 15:06:47 rnpro kernel: BTRFS info (device md0): has skinny extents Aug 28 15:06:49 rnpro kernel: BTRFS: device label 540ed803:data devid 1 transid 361746 /dev/md127 Aug 28 15:06:49 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:06:49 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): open_ctree failed Aug 28 15:11:06 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 28 15:11:06 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:06 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:11:07 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:07 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:11:07 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): open_ctree failed Aug 28 15:23:02 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 28 15:23:02 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:02 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:02 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:23:03 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:03 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:23:03 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): open_ctree failed Aug 29 09:36:23 rnpro kernel: Btrfs loaded, crc32c=crc32c-generic Aug 29 09:36:23 rnpro kernel: BTRFS: device label 540ed803:root devid 1 transid 1169102 /dev/md0 Aug 29 09:36:23 rnpro kernel: BTRFS info (device md0): has skinny extents Aug 29 09:36:24 rnpro kernel: BTRFS: device label 540ed803:data devid 1 transid 361746 /dev/md127 Aug 29 09:36:24 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 29 09:36:25 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): open_ctree failed
