Ken_Ochalek
Feb 03, 2015Aspirant
ReadyNAS Pro 6: will not start to boot menu #24685352
I use a ReadyNAS Pro 6 (RNDP6630D-200) here at the office to store, view and edit hundreds of hours of standard definition video. The unit was purchased in July 2012 and has worked without issue for o...
RX
Feb 03, 2015Luminary
Ken Ochalek wrote: Would removing the discs and powering up be a worthwhile test?
Yup! Let's check the NAS chassis... Pull-out all drives in your NAS and label accordingly from which bay you have pull it out. Then, try to turn on your NAS without drives inside then check if it stays up and it should say "No disks detected" on the LCD display. Check if it will be also be detected on RAIDar.
