Ken_Ochalek
Feb 03, 2015Aspirant
ReadyNAS Pro 6: will not start to boot menu #24685352
I use a ReadyNAS Pro 6 (RNDP6630D-200) here at the office to store, view and edit hundreds of hours of standard definition video. The unit was purchased in July 2012 and has worked without issue for o...
Ken_Ochalek
Okay, I removed the drives with the power off and unplugged. I reattached the power cord, turned the NAS on, and there was no change.
BUT... next I plugged in the network cable, forced shutdown, and restarted. The NAS turned on for a second, turned off, then turned on again after 5 seconds, and booted to the "No disks detected" message on the LCD. RAIDar is detecting the NAS.
Am I right in thinking I should restart to the Boot Menu and run a memory test and/or reinstall the firmware?
