Ken_Ochalek
Feb 03, 2015Aspirant
ReadyNAS Pro 6: will not start to boot menu #24685352
I use a ReadyNAS Pro 6 (RNDP6630D-200) here at the office to store, view and edit hundreds of hours of standard definition video. The unit was purchased in July 2012 and has worked without issue for o...
Feb 03, 2015Guru - Experienced User
If you have a spare disk (not part of the array), doing a factory reset with just that disk installed - just to see that the install completes and the NAS comes up normally.
On the original clock issue, the NAS should have adjusted the time automatically via NTP. Were you using a static IP address?
