Ken_Ochalek
Feb 03, 2015Aspirant
ReadyNAS Pro 6: will not start to boot menu #24685352
I use a ReadyNAS Pro 6 (RNDP6630D-200) here at the office to store, view and edit hundreds of hours of standard definition video. The unit was purchased in July 2012 and has worked without issue for o...
Feb 03, 2015Guru - Experienced User
It sounds like the switch does have an uplink to your corporate network - otherwise you wouldn't be able to reach it via wifi.
If the gateway address or the DNS servers weren't correctly configured,the NAS would not be able to find the DNS server. So that's one thing to check after you get it back up).
It's possible that your corporate firewall is blocking NTP (though it seems a bit unlikely).
Anyway, a typical PC clock can easily be off by about a second a day, and perhaps as much as 10 seconds. (http://tf.nist.gov/service/pdf/computertime.pdf)
