Ken_Ochalek
Feb 03, 2015Aspirant
ReadyNAS Pro 6: will not start to boot menu #24685352
I use a ReadyNAS Pro 6 (RNDP6630D-200) here at the office to store, view and edit hundreds of hours of standard definition video. The unit was purchased in July 2012 and has worked without issue for o...
Feb 03, 2015Guru - Experienced User
If the switch isn't connected to the corporate network, then you are correct. I am thinking the clock isn't relevant anyway.
Can you install RAIDar on the Macs? That will give you a bit more status.
