Ken_Ochalek
Feb 03, 2015Aspirant
ReadyNAS Pro 6: will not start to boot menu #24685352
I use a ReadyNAS Pro 6 (RNDP6630D-200) here at the office to store, view and edit hundreds of hours of standard definition video. The unit was purchased in July 2012 and has worked without issue for o...
Feb 10, 2015Guru - Experienced User
Warranty on the Pro is 5 years, so if you are the original purchaser and bought in 2012, then Netgear should replace the pro-6 under warranty.
