steveoelliott
Nov 03, 2015Luminary
Readynas Pro 6 X-RAID 2 Dual Redundancy Proactive Drive Swap
Hi all,
I have a Pro 6 running 4.2.27 with 4x1TB Hitachi drives (approved on HCL) and am planning to proactively replace 2 of them so from a mechanical / wear perspective the drives in the volume are different. I've heard many horror stories of multiple drive failures when a failure does occur. I figure by having half of my volume on newer disks I reduce this risk to some extent.
Now... I would of course backup my unit (500GB data approx) and then replace one disk at a time, waiting for it to re-sync and become fully redundant. I would then leave a few days for it to settle in and then do another drive.
Is there anything I should be aware of or additional precautions I should take. If it is better I shut down the units rather than hot swap them, then I can do this also. I'm concerned as there are some horror stories on here with folks re-sync's taking days and days and then freezing rendering the whole volume useless.
Is there are rough amount of time each disk should take to re-sync and become redundant on a system with no users.
Thanks...
Hello steveoelliott,
I see. It should still be one at a time, same procedure with expansion. Replace one, let it resync and once done, replace the next disk and so on and so forth.
This might help: How do I replace a disk in my ReadyNAS Ultra, Ultra Plus, NVX or Pro series storage system?
- JennCNETGEAR Employee Retired
We always strongly recommend to have full backup of important data.
Volume expansion may take a day for each disk, depending on how large the volume is. You may visit How do I vertically expand an X-RAID 2 volume on my ReadyNAS OS 6 storage system? article.
- steveoelliottLuminary
Hi,
I will be using identical drives for replacement so there should not be any expansion... Just a re-sync.
I presume this should be faster...
Thanks...
