morgo
May 15, 2017Aspirant
ReadyNAS Pro Business - Random Shutdowns
I have an old ReadyNAS Pro Business that has been serving me well for years now. It's running the latest version of the original operating system. Recently it has started to randomly, or at leas...
- Jun 05, 2017
Just thought I'd post a follow up. I replaced the power supply and have had no further crashes, so it looks like that was the issue.
Sandshark
May 15, 2017Sensei
Is this happening around the same time of day? Perhaps when it's the warmest? Something may be overheating. I had some heat sinks come loose on one of mine, though it didn't cause a shut-down for me.
Bad RAM might cause that, and a RAM test is a simple enough check.
A power supply on its last legs can also cause a problem like that. The power on/off is controlled by the 5VSB (5V standby) power, and there likely is no monitor for that voltage. If it happens too fast, there may not be any warning recorded in the log before the shut-down even for voltages that have monitors. Fortunately, it's an easy fix (search the forum for advice) if it is the supply. If you have a standard ATX supply, you can also attach it externally and run for a couple days to see if that fixes it before you buy a replacement and find that's not the problem. Or if you decide to get another NAS, you can power it that way to recover your data.
I've seen a lot of power on/off related issues posted where it did turn out to be the power supply where I suspect 5VSB was the issue, and I had one myself where 5VSB was definately the culpret. Since it's always on, even when the NAS is off, it's more vunerable.
