morgo
May 15, 2017Aspirant
ReadyNAS Pro Business - Random Shutdowns
I have an old ReadyNAS Pro Business that has been serving me well for years now. It's running the latest version of the original operating system. Recently it has started to randomly, or at leas...
- Jun 05, 2017
Just thought I'd post a follow up. I replaced the power supply and have had no further crashes, so it looks like that was the issue.
morgo
May 16, 2017Aspirant
Thanks for the response. I should have thought power supply. I replaced the original supply several years ago.
In your replay you say that I can attach an ATX supply externally. Silly question, but how do I do this? I tried searching the forums but all I get is posts saying it can be done but not how. I would like to try this option before committing the time / expense of replacing my existing unit. If it is the PSU this time I'll probably just replace the whole NAS.
morgo
How can I tell if the memory test indicates bad memory? I have run the memory test. The first pass went quickly and made 100% with no errors. The second pass has reached 100% with no errors but has been stuck there for a couple of hours. Does this indicate a problem?
