mrwizard93
Sep 03, 2011Aspirant
ReadyNAS Pro HD Video Playback Issues
I am having problems playing videos on my new Mac Mini that I am using as an HTPC. My NAS is a ReadyNAS Pro (RNDP6000) with 3 x 1 TB hitachi ultrastar (HUA722010CLA330) drives and a 1.5 TB seagate...
Sep 09, 2011Guru - Experienced User
You can skip the initial MKVextract step (MKVMerge can directly remux an MKV). However, this is a long shot - if the elementary media streams are corrupted it will not help at all; even if the only damage is to the container layer it seems unlikely.
jelockwood wrote: So, my initial suggestion would be to re-rip using the latest MakeMKV if you can. If you don't have the original source media, then maybe an option would be to demux the media using something like MKVExtract and then remux perhaps using MKVMerge.
If the damage is limited to a small timeslot, you could try transcoding the MKV. If it works, you'd still see/hear some glitches at the point of damage, but it would recover. I author a freeware toolkit which transcodes MKVs, PM me if you are interested.
