ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
ultrabike
Mainly concerned because I was more used to see the Fan SYS at around 700 to 800 RPM, and seeing drives south of 36 degrees. It may have been that the Seagates I had there before (and which died in ~3 years) where cooler. However, what got me concerned is that to reduce noise I tried the Noctua 120mm fan which seemed recommended around here and things got pretty bad with it.
Any recommends to keep things a little cooler and running smoother would be greatly appreciated :-D
