ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
tony359
Jun 20, 2015Apprentice
My 4TB WD (I guess yours have just half of the platters) are 36 degrees right now, and the SYS fan is 800rpm as you would expect. The fan will increase over 42 I reckon - my previous seagate's were constantly going over 42, triggering a high speed fan cycle to cool them down. The WD would never rise more than 36 (maybe 38 under load) so the fan never runs faster than 800. I have 18 degrees in my home right now though.
Your SYS temp seems a little high, mine is 49 at the time being. CPU is also cooler, mine is 21. The unit is idle of course.
Did you try to recalibrate the fan speed? What is your ambient temperature?
