ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
ultrabike
Yup. Recalibrated plenty of times. I'm almost sure it's not the drives or the CPU but the memory/raid(?) controller. The heatsink of those gets pretty hot.
That's what I was thinking if maybe changing the CPU would ease things for those two or something.
It could be something else... Any ideas? :(
BTW, just removed the side cover (around the motherboard), and in 2 minutes things are looking like this:
Device Description Status
Disk 1 WDC WD20EARX-00PASB0 1863 GB , 34 C / 93 F , Write-cache ON OK
Disk 2 WDC WD20EARX-00PASB0 1863 GB , 33 C / 91 F , Write-cache ON OK
Disk 3 WDC WD20EFRX-68AX9N0 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 4 WDC WD20EFRX-68AX9N0 1863 GB , 32 C / 89 F , Write-cache ON OK
Disk 5 WDC WD20EZRX-19D8PB0 1863 GB , 32 C / 89 F , Write-cache ON OK
Disk 6 WDC WD20EARX-00PASB0 1863 GB , 31 C / 87 F , Write-cache ON OK
Fan SYS 1068 RPM OK
Fan CPU 1548 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 35.5 C / 95 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 19 minutes OK
... and from what I remember, will continue to drop.
Fan SYS 1068 RPM OK
Fan CPU 1548 RPM OK
