ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
ultrabike
Jun 21, 2015Aspirant
As far as heat, it seems the motherboard rests on the side close to where HDD 1 and 4 are. The hottest one is HDD 1, and the Pro has a heatsink right on below the CPU and adjacent to HDD1 I think.
Things did not immediately spin down, but with the cover off these are my numbers now:
Device Description Status
Disk 1 WDC WD20EARX-00PASB0 1863 GB , 28 C / 82 F , Write-cache ON OK
Disk 2 WDC WD20EARX-00PASB0 1863 GB , 27 C / 80 F , Write-cache ON OK
Disk 3 WDC WD20EFRX-68AX9N0 1863 GB , 27 C / 80 F , Write-cache ON OK
Disk 4 WDC WD20EFRX-68AX9N0 1863 GB , 28 C / 82 F , Write-cache ON OK
Disk 5 WDC WD20EZRX-19D8PB0 1863 GB , 28 C / 82 F , Write-cache ON OK
Disk 6 WDC WD20EARX-00PASB0 1863 GB , 26 C / 78 F , Write-cache ON OK
Fan SYS 969 RPM OK
Fan CPU 1548 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 33 C / 91 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 19 minutes OK
As far as dust, I removed dust all over and can fell airflow coming out of the unit.
What CPU do you have currently?
Fan SYS 969 RPM OK
Fan CPU 1548 RPM OK
