ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
ultrabike
Jun 21, 2015Aspirant
LOL! I opened mine. Had to since it needed a power supply change.
Yes, it was pretty dirty. But now it's relatively clean. I just gave it another pass and this time I upgraded the BIOS to the latest (for 4.2.27). We'll see what it does. Might be able to upgrade the CPU with a used E7600 too.
As far as fans. Yes, the only one that pushes air out is the 120mm big fan. The CPU and PSU fans push air towards the CPU and towards the insight of the supply. The mesh is unobstructed and can feel the air being pulled through it.
Right away the temperatures raised:
Disk 1 WDC WD20EARX-00PASB0 1863 GB , 32 C / 89 F , Write-cache ON OK
Disk 2 WDC WD20EARX-00PASB0 1863 GB , 29 C / 84 F , Write-cache ON OK
Disk 3 WDC WD20EFRX-68AX9N0 1863 GB , 28 C / 82 F , Write-cache ON OK
Disk 4 WDC WD20EFRX-68AX9N0 1863 GB , 30 C / 86 F , Write-cache ON OK
Disk 5 WDC WD20EZRX-19D8PB0 1863 GB , 29 C / 84 F , Write-cache ON OK
Disk 6 WDC WD20EARX-00PASB0 1863 GB , 28 C / 82 F , Write-cache ON OK
Fan SYS 1577 RPM OK
Fan CPU 1520 RPM OK
Temp SYS 61 C / 141 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 36 C / 96 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 19 minutes OK
It may also be thermal paste somehow. I did remove the CPU fan at some point to clean it up. Will check if adding more of that helps.
Fan SYS 1577 RPM OK
Fan CPU 1520 RPM OK
