ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
tony359
Jun 24, 2015Apprentice
That sounds as a good method, as you see the point is you have to put a very tiny amount of paste. Thanks, this method is probably better than the one I suggested.
Stephen,
That's what ultrabike said : the HDDs shut down if he replaces the fan.
Stephen,
