ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
ultrabike
Jun 24, 2015Aspirant
I also feel something is odd. But yes, the HDD's got fairly hot in minutes (not exagerating) with the Noctua fan.
As far as I know nothing heavy should be running. I can SSH and do a top to see what's gong on.
As far as my ambient temperature, I'm in Irvine CA which is not too bad.
The unit is not dying if the SYS fan is the stock fan, though temperature is a bit higher than what I would expect, and the fan is running somewhat fast. However, with the Noctua SYS fan, things go down in flames. I already ordered a second CPU fan to see if things improve (note I have so far replaced or attempted to replace every fan except the CPU fan, which might be running too slow).
