ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
ultrabike
Jun 25, 2015Aspirant
Just changed the cpu to a E5300. Other than having a better processor not much difference:
Disk 1 WDC WD20EARX-00PASB0 1863 GB , 32 C / 89 F , Write-cache ON OK
Disk 2 WDC WD20EARX-00PASB0 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 3 WDC WD20EFRX-68AX9N0 1863 GB , 29 C / 84 F , Write-cache ON OK
Disk 4 WDC WD20EFRX-68AX9N0 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 5 WDC WD20EZRX-19D8PB0 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 6 WDC WD20EARX-00PASB0 1863 GB , 28 C / 82 F , Write-cache ON OK
Fan SYS 1520 RPM OK
Fan CPU 1520 RPM OK
Temp SYS 59 C / 138 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 34 C / 93 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 19 minutes OK
Here is what SSH has to say about what's running on my NAS:
Doesn't seem like much is running. Will test my luck with the rewiring and the new CPU fan.
Fan SYS 1520 RPM OK
Fan CPU 1520 RPM OK
Last login: Wed Jun 24 19:49:31 2015 from 192.168.1.109
Last login: Wed Jun 24 19:51:57 2015 from 192.168.1.109 on pts/0
Linux READYNASPRO1 2.6.37.6.RNx86_64.2.4 #1 SMP Wed Aug 20 11:41:34 PDT 2014 x86 _64 GNU/Linux
READYNASPRO1:~# top
top - 19:53:34 up 6 min, 1 user, load average: 0.33, 0.55, 0.32
Mem: 1021064k total, 992632k used, 28432k free, 429592k buffers
Swap: 2096892k total, 0k used, 2096892k free, 144032k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3306 root 20 0 26348 3224 2664 S 1 0.3 0:02.15 leafp2p
1 root 20 0 2068 664 564 S 0 0.1 0:00.80 init
2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0 0.0 0:00.00 ksoftirqd/0
6 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/0
7 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/1
8 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/1:0
9 root 20 0 0 0 0 S 0 0.0 0:00.00 ksoftirqd/1
10 root 20 0 0 0 0 S 0 0.0 0:00.03 kworker/0:1
11 root 0 -20 0 0 0 S 0 0.0 0:00.00 khelper
158 root 20 0 0 0 0 S 0 0.0 0:00.00 sync_supers
160 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default
162 root 0 -20 0 0 0 S 0 0.0 0:00.00 kblockd
163 root 0 -20 0 0 0 S 0 0.0 0:00.00 kacpid
164 root 0 -20 0 0 0 S 0 0.0 0:00.00 kacpi_notify
165 root 0 -20 0 0 0 S 0 0.0 0:00.00 kacpi_hotplug
272 root 20 0 0 0 0 S 0 0.0 0:00.00 khubd
279 root 0 -20 0 0 0 S 0 0.0 0:00.00 md
380 root 0 -20 0 0 0 S 0 0.0 0:00.00 rpciod
381 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/1:1
407 root 20 0 0 0 0 S 0 0.0 0:00.01 kswapd0
473 root 20 0 0 0 0 S 0 0.0 0:00.00 fsnotify_mark
475 root 0 -20 0 0 0 S 0 0.0 0:00.00 aio
491 root 0 -20 0 0 0 S 0 0.0 0:00.00 nfsiod
507 root 0 -20 0 0 0 S 0 0.0 0:00.00 crypto
524 root 0 -20 0 0 0 S 0 0.0 0:00.00 kthrotld
569 root 0 -20 0 0 0 S 0 0.0 0:00.00 scsi_tgtd
601 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_0
604 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_1
607 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_2
610 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_3
613 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_4
616 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_5
623 root 20 0 0 0 0 S 0 0.0 0:00.19 kworker/u:6
624 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/u:7
629 root 0 -20 0 0 0 S 0 0.0 0:00.00 bond0
694 root 0 -20 0 0 0 S 0 0.0 0:00.00 kstriped
697 root 0 -20 0 0 0 S 0 0.0 0:00.00 ksnapd
698 root 0 -20 0 0 0 S 0 0.0 0:00.00 kondemand
699 root 0 -20 0 0 0 S 0 0.0 0:00.00 kconservative
702 root 0 -20 0 0 0 S 0 0.0 0:00.00 usbhid_resumer
