ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
ultrabike
Jun 27, 2015Aspirant
Welp. I don't have proof about the Disk 1 shutting down. But here are the temperature alarms:
The CPU fan did not solved it, but it's pushing more air...
Device Description Status
Disk 1 WDC WD20EARX-00PASB0 1863 GB , 33 C / 91 F , Write-cache ON OK
Disk 2 WDC WD20EARX-00PASB0 1863 GB , 32 C / 89 F , Write-cache ON OK
Disk 3 WDC WD20EFRX-68AX9N0 1863 GB , 30 C / 86 F , Write-cache ON OK
Disk 4 WDC WD20EFRX-68AX9N0 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 5 WDC WD20EZRX-19D8PB0 1863 GB , 31 C / 87 F , Write-cache ON OK
Disk 6 WDC WD20EARX-00PASB0 1863 GB , 30 C / 86 F , Write-cache ON OK
Fan SYS 1493 RPM OK
Fan CPU 1939 RPM OK
Temp SYS 59 C / 138 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 31 C / 87 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS ES 550, Battery charge: 100%, 17 minutes OK
Will see if I can improve air flow by crimping cables...
EDIT:
Removed the extra connector and crimped the cables. No difference.
So, completely clueless as to what is causing the Temp SYS to go high.
Fan SYS 1493 RPM OK
Fan CPU 1939 RPM OK
EDIT:
