ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
tony359
Jun 27, 2015Apprentice
I'm with Stephen here.
You live in California, Google says 28°C today. I have probably around 18°C on the floor where I keep my NAS. Let's say 5°C difference. Then you have 6HDD's, which are going to make a difference for sure. I am not sure when the SYS fan is speeding up, I know it speeds up when the HDD's go beyond 42°C if memory serves, not sure about the SYS temp.
To find out more I stuck an heater in front of the NAS :)
The SYS fan speeds up slightly (927 from 892) till the temp reached 60°C, then it ramps to 1300rpm. The extra airflow manage to cool the box enough so the temp then dropped to 59°C, despite the heater in front of it.
So I put both CPUs to 100%. The CPU fan speed ramped up to 4000rpm within a minute or so, then the HDDs managed in the meantime to go over 42°C and the SYS fan speeded up again to 1700rpm. That again was enough to keep the CPU below 65°C and the SYS below 60°C. It was not going any higher and the SYS fan was not running at 100%.
Once the heater was turned off, it took say 5 minutes to go back to normality (the CPU takes less time). The SYS fan eventually dropped to the usual low speed after more time - the fan is waiting for the HDDs to go below the threshold of 42°C. It took 11 minutes for that to happen.
