ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
tony359
Jun 28, 2015Apprentice
The Sys temp is just 4°C lower, maybe it's just a cooler day! I may be mistaken but I feel you are overlooking the importance of the ambience temperature.
I do not know where the SYS temp sensor is, maybe it was just slightly misplaced on the old unit?
I kind of remember that the Motherboard is then resting on the chassis as well for heat dissipation, behind the CPU, but I may be mistaken.
