ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
itsjasper
Jun 29, 2015Luminary
Weren't the v1 Pro units known for reporting high system temps (something related to the temp sensor placement on the Northbridge IIRC)?
I remember my first v1 Pro exhibiting similar behaviour under v4.x, it was always close to the upper limit and triggering alarms in summertime. I don't recall ever having a problem with it other than the alerting.
I don't recall it triggering alarms under OS6, though I'm not sure if that is an OS6 thing, or because it has been relegated to test duties in the basement. I'll bring it upstairs and see what it reports.
