ultrabike
Jun 20, 2015Aspirant
Readynas Pro heat issues
Hopefully this is the right place to post this. I've had my Readynas Pro for about 7 years. Recently the power supply fan started to make funny noises and temperature was kind of high. Scheduled power...
tony359
Jun 29, 2015Apprentice
Well if the SYS temperature sensor is on the Northbridge... that would explain many things. I thought it was actually sensing the air out of the box! And that would explain why removing the side panel would slow down the fan, there is no 'fresh air' getting into the motherboard vane, where the NorthBridge is, all the fresh air goes into the CPU and only when it's been warmed up it then enters the MB vane.
How do I distinguish between V1 and V2? Is the sensor an actual sensor (i.e. a wire) or is it embedded into some electronics?
