Retired_Member
Nov 07, 2015Readynas Pro not booting
Hi I have a Ready Nas Pro Business (2010 unit I think) from a few years ago. I recently had to reboot it due to a power cut. When it now boots it starts, fans going full and just sits on "READYN...
- Retired_MemberNov 11, 2015
Initally it would not power on. I unplugged the power cable, plug it back in again, and then tried to turn on at back switch and front button. Tried this like 20 - 30times and then suddendly it powered up. Weirdly after that, no issue with powering up again. I found you HAD to remove the power cable each time. Once i got it powered on it failed to boot it was stuck on readynas logo. Restarted a load more times and suddenly it worked. Backed everything up - and now unit in bin! As i also got an EOL on this unit from Netgear today, QNAP TS-253 Pro here I come :-)
JennC
Nov 07, 2015NETGEAR Employee Retired
Hello punderwood75,
I have some questions to ask, I've summarized them below:
- Is the NAS connected to your local network?
- Do you have RAIDar installed to your computer that is on the same LAN where the NAS is? If so, does the RAIDar detect the NAS?
- If RAIDar detects the NAS, what does it show? Please post a screenshot.
- How many disks are inserted? What's the size of each?
- Do you have back up copy of the files stored to the disks?
- Retired_MemberNov 07, 2015
Hi
Yes connected to local network, but cannot ping it so no raidr does not find it. i dont think the box is even booting that far.
No backup :(
4 x 2TB drives in RAID5 with 1 spare
- JennCNov 07, 2015NETGEAR Employee Retired
Hello punderwood75,
Always have full back up of your files, we always strongly recommend that.
How's the LED activity?
Please connect the NAS straight to the computer that has the RAIDar and see of RAIDar will detect it.
