greenleaf-noho
Dec 28, 2015Aspirant
ReadyNAS Pro Pioneer - Cannot allocate memory failure
I have a ReadyNAS Pro Pioneer (RNDP600E-100NAS) that is running on firmware version RAIDiator 4.2.28 with memory of 1024 MB [4-5-5-15 DDR2] with 2 - 1.5TB Seagate Barracuda SATA 7200 RPM, 32MB (ST315...
- Jan 02, 2016
Perhaps try this registry settings change?: http://superuser.com/questions/362331/cannot-allocate-memory-moving-files-over-network-share
mdgm-ntgr
Jan 01, 2016NETGEAR Employee Retired
The email never arrived. Can you check you sent it to the correct address?
Perhaps also try sending it from a different email address.
greenleaf-noho
Jan 02, 2016Aspirant
Thanks for your response, logs resent just now.
Happy New Year!
- mdgm-ntgrJan 02, 2016NETGEAR Employee Retired
Odd. I still can't see them. Perhaps try a different email address or if you've already done that PM me a link to the zip file.
- greenleaf-nohoJan 02, 2016Aspirant
I just resent the files again, this time extracted from the zipped file. I am not sure what 'PM' stands for.
- StephenBJan 02, 2016Guru - Experienced User
PM-> private message.
You send them using the "messages" link at the top right of the forum page.
