mtrac
Dec 01, 2012Aspirant
ReadyNAS Pro Pioneer 4.2.22 hangs
I've seen other posts about ReadyNAS Pro's hanging, but didn't notice anything current. In the past several months, my ReadyNAS Pro Pioneer hangs. (It may have been doing it longer, but I was out ...
kato05
Mar 14, 2013Aspirant
StephenB, thanks for your input.
Since I turned off automatic spin-down I have not had an issue in the last week. I don't consider this a solution as it was working fine with spin-down turned on for quite a long time. When I get a chance I'll re-enable it and see if the problem returns. If the problem does return I'll follow your suggestion of a reinstall.
