bbb555
Jan 18, 2022Tutor
ReadyNAS Pro Pioneer Edition OS6.10.6 Missing Volume and Performance Status
Had a drive fail in the NAS while running OS4. I removed the failed drive and ran the volume unprotected and took the opportunity to backup all my data. After the backup was finished, I followed the ...
Jan 18, 2022Guru - Experienced User
bbb555 wrote:
The issue that I've noticed is that the GUI is not showing anything under the System -> Volume page. It is also showing nothing under System -> Performance -> Status. Other Performance details Volume, Network, Utilisation, Temperatue are all showing.
Have you tried clearing the browser cache?
- bbb555Jan 18, 2022Tutor
Tried it on two different machines - desktop and laptop and different browsers on each.
Clearing cache, cookies etc ... still no luck
- StephenBJan 18, 2022Guru - Experienced User
Odd. Any internet security suites running?
- bbb555Jan 18, 2022TutorNo internet security suites running.
essentially, i could see the drives when it was converting to X-RAID, but once that finished and then expanded into the 6th drive, i could no longer see those details.
i’ve half copied over my data so far ~4TB, so trying to avoid a factory reset.
