bbb555
Jan 18, 2022Tutor
ReadyNAS Pro Pioneer Edition OS6.10.6 Missing Volume and Performance Status
Had a drive fail in the NAS while running OS4. I removed the failed drive and ran the volume unprotected and took the opportunity to backup all my data. After the backup was finished, I followed the ...
bbb555
Jan 18, 2022Tutor
Tried it on two different machines - desktop and laptop and different browsers on each.
Clearing cache, cookies etc ... still no luck
Jan 18, 2022Guru - Experienced User
Odd. Any internet security suites running?
- bbb555Jan 18, 2022TutorNo internet security suites running.
essentially, i could see the drives when it was converting to X-RAID, but once that finished and then expanded into the 6th drive, i could no longer see those details.
i’ve half copied over my data so far ~4TB, so trying to avoid a factory reset.- bbb555Jan 18, 2022Tutor
bit the bullet and did a factory reset.
took 6 hours to do a volume sync, but didn't fix the issue of not seeing any volumes or performance status info.
am at a bit of a loss :/
removed the 6 drives and tried 2 new drives (being kept as cold spares).
booted up and went through the setup, it chose RAID1 and began synching.
checked the two pages, still facing the issue.
reverted back to the 6 drive raid setup.
bit puzzled ...
