kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Dec 05, 2013Guru - Experienced User
Are you using Windows 8?
If so, you might try 4.2.25. It has a fix for "SMB allocation roundup" which you might need.
Also, do you have the recycle bin enabled?
