kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Etz
StephenB wrote: Are you using Windows 8?
If so, you might try 4.2.25. It has a fix for "SMB allocation roundup" which you might need.
If he uses Windows 8 he shouldnt have a problem and dont need that fix.
It only affects windows 8.1 users.
Which doesnt mean it wouldnt be advisable to keep NAS up to date, unless there is some known bugs in newer firmware.
