kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Etz
kenzok2002 wrote: correction some of my machines are windows 8.1 and some are windows 8
Then I would also recommend you to upgrade your NAS to 4.2.25 as StephenB suggested above.
Also, as Windows 8.1 is a free update for Windows 8 users, you probably will run 8.1 on all machines at some point and then you will definately have that issue.
