kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Etz
kenzok2002 wrote: Ok updated to 42.25 and its still showing 81% full...
It wont Fix anything in Frontview but in Windows explorer view.
Youre Volume is probably 81% full as it shows.
Do you have Recycle Bin enabled on shares?
kenzok2002 wrote: I am also running Egnyte Add-on, which is an old version they have told me to update... anyone have any other ideas?
Not sure about this maybe someone else can comment?
I dont use Egnyte myself.
