kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Dec 05, 2013Guru - Experienced User
One option is to install SSH and start looking folder by folder within linux.
You can do the same thing from Windows by access \\nasname\c with username=admin, pass=nas password. It will be slower, since you are gathering all the data over the network, but it will work.
