kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Dec 06, 2013Guru - Experienced User
Yes, the "home" folder holds all the user home shares.
You can see them from ssh, you can also access the NAS using Windows File Sharing using the NAS admin account credentials.
Do you want to disable the home shares completely? Or just clean up old data?
