kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Dec 06, 2013Guru - Experienced User
Apparently they are not so empty (7 TB total, not ~200GB).
For cleaning them out, the easiest way is to use the windows file sharing method above. You might want to set the folder option to see hidden files.
