kenzok2002
Dec 05, 2013Aspirant
Readynas Pro Reporting much larger used volume than total of
I have a Readnynas Pro Pioneer unit running firmware 4.2.24 In front view its reporting that I have used 81% of my disk space 7577GB of 9250 GB (spread across six 2 TB disks in X-Raid2) Windows also...
Etz
Dec 06, 2013Aspirant
kenzok2002 wrote: I'm thinking it may be time for a backup and factory reset unless someone can tell me how to delete the home share... is it automatically created by the nas as its not in the share listing
I dont think it is advisable to delete whole /home/ folder as it probably wont get recreated unless you do a firmware reinstall.
Its not in the share listing as it is a integral part of Linux installation and it isnt technically share, shared are only user folders under it.
For Linux system /home/ is a directory where User files are created and kept. It is basically equivivalent of C:\Users folder in Windows.
