jabberwockie1
Oct 27, 2014Aspirant
Readynas Pro RNDP6350 won't boot
Hello, Powered this unit down before our big windstorm here in the Northwest, went to boot it up 2 days later and nothing. I can see a little bit of flickering from the lan port LEDs (no network cab...
jabberwockie1
mdgm wrote: When did you purchase this NAS?
There are some threads on replacing the PSU. An extender cable would be needed.
I wouldn't suggest purchasing a Pro/Pro 6 at this stage. Those units are discontinued.
Purchase e.g. a 316 (dual-core Atom CPU 2GB RAM) or a 516 (dual-core Ivy Bridge 4GB RAM).
We do have a procedure that can be used to recover the data from a Pro (assuming the disks and array are fine) using our new models. You would need somewhere to backup your data to. In future I would suggest hat you backup your data regularly.
..but if I did find Pro 6, cheap, just to recover the data , would it be as simple as pluging in the drives.
regarding the Power supply - are they pretty standard?
