jabberwockie1
Oct 27, 2014Aspirant
Readynas Pro RNDP6350 won't boot
Hello, Powered this unit down before our big windstorm here in the Northwest, went to boot it up 2 days later and nothing. I can see a little bit of flickering from the lan port LEDs (no network cab...
mdgm-ntgr
Oct 27, 2014NETGEAR Employee Retired
You should put a spare disk (must not be from your array) in the Pro 6 and make sure the firmware is at least as up to date as that on the Pro, then power down, remove the spare disk and migrate your disks across.
Here is a suggested replacement PSU: https://www.readynas.com/forum/viewtopic.php?p=424298#p424298
Assuming the problem is just the PSU replacing it should solve the problem, but if the problem is more than that...
