jabberwockie1
Oct 27, 2014Aspirant
Readynas Pro RNDP6350 won't boot
Hello, Powered this unit down before our big windstorm here in the Northwest, went to boot it up 2 days later and nothing. I can see a little bit of flickering from the lan port LEDs (no network cab...
jabberwockie1
mdgm wrote: The migration procedure is here: http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
It shouldn't matter if the firmware is newer on the replacement unit, but it may matter if it is older. You can't downgrade to 4.2.15 after updating to newer firmware.
If in doubt, put the latest firmware on the replacement unit.
Ok- good stuff - one more thing. I forgot to mention, I had had replaced the cmos battery as part of the diagnosis. Does this impact anything?
