jabberwockie1
Oct 27, 2014Aspirant
Readynas Pro RNDP6350 won't boot
Hello, Powered this unit down before our big windstorm here in the Northwest, went to boot it up 2 days later and nothing. I can see a little bit of flickering from the lan port LEDs (no network cab...
mdgm-ntgr
Oct 27, 2014NETGEAR Employee Retired
Provided you used the same type of battery and installed it correctly that shouldn't be a problem. The battery is primarily used for storing the time when the NAS is off.
