jabberwockie1
Oct 27, 2014Aspirant
Readynas Pro RNDP6350 won't boot
Hello, Powered this unit down before our big windstorm here in the Northwest, went to boot it up 2 days later and nothing. I can see a little bit of flickering from the lan port LEDs (no network cab...
jabberwockie1
Oct 29, 2014Aspirant
mdgm wrote: Provided you used the same type of battery and installed it correctly that shouldn't be a problem. The battery is primarily used for storing the time when the NAS is off.
Ok - ordered the replacement power supply and extension cable with the link you provided.
Are there any good instructions/pic on how to remove the existing supply?
