sirozha
Jul 05, 2012Aspirant
ReadyNAS Pro unresponsive on 4.2.21 - first time in years.
My ReadyNAS Pro Business became unresponsive for the first time in years. It was not showing under SHARED on my Mac this morning. When I tried to ping it, I got nothing. RAIDar did not detect it, so I...
mdgm-ntgr
Jul 06, 2012NETGEAR Employee Retired
Try both "df -h" and "df -i". The first can be used to see if the space on the OS partition (/dev/md0) is filled up. The latter can be used to see if the inodes are used up (i.e. lots of small files). Too full would be something approaching 100% full (say over about 80% perhaps). Normally the OS partition would be well under half full.
The output of "df -h" is shown in disk_usage.log in the logs zip file but using SSH would give you up-to-date output.
I presume this is on your beta unit?
